New to building, Self intruduction and Questions
I have always been into computers but have never built one till now. There was a short period of time while in college I was a MAC user and I didn't play much video games. Now that I am getting to be latter in my 20's and have stopped going out and parting everyday I have been getting back into my old love, the PC. Two years ago I got a crappy off the shelf HP from Best Buy and with that I dropped my mac and got back into PC gaming. When I was younger I owned almost every console because my dad was a tech nerd however 90% of my gaming I did on PC. Some of my founder memories of my video game youth are LANing game like Quake and WC2 and playing against my dad and brother. So recently my video game nerdom has spread over to being really into hardware. My off the shelf HP broke last month and I decided I am going to build my next one. So thanks to The Tek and Linus I was easily educated in how to do this and the process seemed a lot easier than I thought i'd be when I was a kid. Ordered all the parts off Amazon except for the graphics card I got from NewEgg. I took the DVD drive, Harddrive, 8 gigs of ram and my graphics card out of my HP.  Just finished putting it together and I don't think anything is more rewarding than hitting that button and it firing up the first time. I really enjoyed every part of the process from picking the parts to putting it all together.
anyway that was just little introduction. My Pc specs are in my profile if you care.  I do have a few questions for anyone that know the answer.
My Computer is hooked up to my living room TV and I use a wireless mouse and keyboard and for some reason they are both MUCH less responsive on my new computer. I have tired downloading Drivers and everything. Its the same distance away from me as the last computer. Idk if because I have it plugged into the back if all the other electronics are messing with the signal because I don't have my front panel USB hooked up because the way my motherboard was. Do you thinking getting a USB extender and getting the dongol away from everything and closer to me would help my problem?
My case is the cosair 200r and has room for fans on the top and side, I am currently not over cloaking and only running with the 2 fans that came with the case (not counting CPU,GPU and Power)  My off the shelf HP I think died due to the Heat. Should I get more fans now or am i fine to wait till I plan on overclocking? I was going to wait till i had the money for some kind of self contained water cooling for the CPU and than also put 2 fans on the side. Or is waiting till than a bad idea and I should just get the side fans now.
When you use USB adapters directly attached to the back of the motherboard, your gonna have a bad time...  #1 it has to reach its signal around your computer tower #2 there is a big magnetic field around there because of the PSU and all the activity...  Get a 3 foot extension cable or get your front ports working.
When it comes to airflow it all depends on the setup...  The only real recommendation I can give you without seeing it myself is maintain a positive air pressure.  Which means have air pushing into the case via fans so hard, that all the other holes push air out.  This means that you can direct air flow more intentionally, plus dust wont sneak into the system on accident (you should bring air via a fan that has a filter on it).
thanks that what i figured about my keyboard, since i have to order the adapter i may as well buy 2 more cheap fans to get more air pressure coming in just to be on the safe side.
Doesn't the motherboard have front USB headers?
