New system with xeon 1231v3
So, I'm (think of) building a new workstation with the Xeon 1231v3. Current spec list is as follows:
Xeon 1231v3.
AsRock Z97-Pro 4
Adata Sx900 128gb
WD Black 2 TB
Asus Strix 960 4gb/ Strix 380 4gb
Kingston HyperX 16gb
Corsair Rm 750
Improvements? Thoughts? (Insults?)
Will be using it for editing photos/videos, gaming, sorcery.
I've just dribbled on my keyboard!!!! :oP
That you, my good sir. That you have.
looks out the window and sips tea
What is your country and budget?
Estonia,
no real budget, but the sub 1500€ range. ish
hmmmmmm
can you link us a few websites you can buy from?
http://arvutitark.ee
Go for the 4gb 380 and I'd say thats a good build. I'm actually using a 1231-v3 and a 980 ti as my daily desktop ( http://pcpartpicker.com/p/szNtGX ), and its a great chip in my opinion. I also employ the AsRock Extreme6 which is has been great, and its basically just the Extreme4 with a couple extra bells and whistles.
Give me a few minutes to try and make the formatting work. Here is what I have now. Its a good bit more expensive than what you had, but its also a lot more powerful.
TOODE TARNEAEG
KOGUS
HIND SUMMA
Intel® Core™ i7-5820K Processor 423.59€
CRUCIAL MEMORY DIMM 16GB 85.24€
MSI X99A RAIDER, X99 238.40€
SAMSUNG SSD M.2 2280 256GB/950 PRO 207.12€
PSU Cooler Master GM seeria G550M 550W, 80 PLUS pronks, 65.21€
SEAGATE HDD SATA 1TB 7200RPM 6GB/S/64MB ST1000DM003 52.90€
Cooler Master "HYPER 212 EVO", 37.50€
GIGABYTE VGA PCIE16 R9 380 4GB 254.84€
BitFenix Shinobi 56.86€
Tellimuse eeldatav täitmise aeg: 1-5 tööpäeva Kokku: 1 421.66€
Right.
Thanks for the help. I probably won't be building the system now, as my current workstation is still sufficient, but in the next few months. I'll also make a few changes to your supposed build, but thank you tremendously for helping with the sketch.
Cheers.
Well what is your current setup? If its working for you, maybe all you need is a few bits and bobs to extend its life.
