So I’m at wits end with my most recent build and looking for a second set of eyes to see if I’m on the right path.
I bought the following parts for an upgrade to my gaming/eventual KVM rig:
Ryzen 2700x
32gb of gskill pc3200 ram (2x16), running at 2133 until I figure out the GPU issue
Asrock Taichi X470
Radeon RX580
GTX1080 (from my previous build, rock solid previously)
RX Vega64 (when all the GPU issues kept showing up with 580+1080)
New PSU (1kw gold, EVGA I believe)
The issue it’s running into are GPU driver crashes, AMD and NVidia exhibit the same behavior. I’ve tested single cards, two cards, different pcie slots, different OSs.
RAM has passed memtestx86 with a clean bill of health after 3 full cycles.
Windows 10 RTM and 1809 exhibit the same issue, as soon as you stress the GPU, be it Firefox or Games, the display drivers crash.
Each OS attempt has been using a fresh format/ reinstall as well
I’ve run CPU stress tests with prime95 for 2+ hour runs, which had normal thermals during the run.
I tried running a GPU stress test from a Xubuntu live USB this morning to try and rule out windows entirely, which hard locked as well inside 15 seconds on fur mark
At this point, I’m down to it being either the motherboard or the cpu, but at this point I’m not sure which one might be the root. I’m tempted to lean towards the motherboard, since the instability seems to follow pcie (bus or power) loading (single 580 is more stable than 580+1080, which is more stable than 580+Vega, which is more stable than Vega+1080).
Any suggestions you all might have would be greatly appreciated.
