Hello, New to the forum. I'm Building a new computer and need some input on the fitting and compatability. Critizism, tips and ideas are all welcome. Thanks
For one why would you go 2011. Unless your getting a six core to me 2011 is a waste and your better off with 1155. aswell that processor is not overclockable and will be fast now but in the future will be slower compared to newer stuff.
Other than that I would reccomend a 1155 motherboard and a 3770k
A 20" a screen? Maybe you could swap the 600T for a 300R or 200R, which will do just as good, so you can put a little more money to the screen. Or maybe downgrade that keyboard
As for the gpus, that evga is a reference 4gb, and i linked you an after market cooled 2gb card. I guess you'd say the evga would offer a better rounded workstation, but you could grab the 4gb version of the MSI card just as easily. It's up to you i was just saving you money on stuff you dont need.
As far as I know, as long as your okay with overclocking, none. If not, and usually if money is not a problem, the one with the higher clock might be better
