New Project for a future PC: Project Master Sword
So I'll make this short. I am planning a PC to be my magnum opus in terms of power and speed. This will be a multi-tasking calculative holy grail of majestic proportions to handle the following:
  • Streaming
  • Gaming
  • 3D Rendering
  • Programming
  • Video Rendering
And it cannot be hot and/or spike the CPU as I perform these task when everything is maxed from games to stream software simultaneously.
Here is the list of the parts:
http://pcpartpicker.com/user/LULZrookOFtheBANNED/saved/nC3MnQ
Opinions and suggestions are deeply appreciated especially on compatibility issues like for example, do I need to download a bios or can this handle all the RAM I can add. Something like that. Thank you and stay awesome, teknicians.
Edit: I'll get the A399U Monitor Wendell reviewed, therefore there is no monitor included in the list.
I think that the Dell panel you have chosen is the same panel that is in the Samsung 4k U28D590D - if it is DO NOT BUY IT.
There are much better screens for similar money.
Depending on what type of production you are doing you may want to look at getting a true 10 bit panel.
EVGA makes a superclocked version of the Titan X if you want that is less than $50 more
Be careful with ram choice if you want to overclock much - I would stick with 2400mhz if thats the case
Maybe look into the Samsung 850 PRO instead of the Adata SSD just from a durability perspective
That case would work better with 140mm fans and they are quieter than the 120mm
Other than that is looks good! (IMHO)
the listed is edited now on pcpartpicker. I think it looks great now.
Shouldn't you use something better for the thermal paste?
You need the magnum opus of thermal paste after all.
I switched it to my favorite thermal compound that I use for my AMD Gaming PC, the Arctic Silver MX4. If we all know about AMDs, they tend to be a little hot when on load bit with this thing, my AMD is frozen solid (exaggerating, but I hope you get the point.)
If you want to throw a bit more money at the display, that new 'cheap' 4k monitor Wendell reviewed might be worth a shot. I have never used 4k myself, but I believe the general consensus that having such high pixel density is great for productivity. Just a thought.
Otherwise, I really like it! Makes my mouth water. XD
Yea was looking at the MX4 stuff. At the moment using AS5 when I got it from a Radioshack that was closing.
Pictures when this Magnum Opus is made?
hopefully it will be done at the end of August. But yeah, pictures, indefinitely.
Just a thought to put in your head: Depending on what your doing, check if IPS monitors are a must or not. I prefer IPS monitors, but then again, I don't game as much. If I had to get a 4K monitor, I would wait for an affordable 4K AH-IPS monitor.
