hi there guys
So my psu bombed out on me today(hp) ( i stay in south africa , had a power surge today no fault of my own as i wasnt arround).
The oem psu was 16pin(atx)+4pin(cpu) for the mobo
i was just curious to know if i could get a modular psu to replace or am i forced to get an oem one and pay through my butt for a 400w psu
much thanks
raj
You probably need something like this to adapt a normal power supply to it, just with the right pin count naturally
Thank you for your help
you have helped me save a lot of money
much appreciated
I'm not 100% though on if an adapter would be safe, because you'd be converting 20 pins into 16 pins, are you sure it's 16 pins? Do ya got a picture?
i just double checked and its 20 pins
i think in my state of panic i must have gotten confused
what would you recommend as a replacement between $50-$60 ?
Ordering from the US?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182329&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Scratch that last one, 20 dollar Mail in rebate
But ya that HP thing is just a smaller 20 pin I guess to save motherboard space maybe. I got one once, but as it turns out the motherboard had died at some point
ill try to source locally
we have a very stiff import tax here
this is probably the best one i can source locally within my budget
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139050 or
http://www.gigabyte.co.za/products/product-page.aspx?pid=4283#kf
Should be fine, modular is always the way to go.
