New pc wont detect wifi card
So i just finished building my new pc, but it wont detech the wifi card attached to it, so i can get on the internet or install the drivers. Its plugged into the very bottom slot here. My wifi card is this Anyone know how i can fix it?
The drivers disk is a good place to start or go to their site and download the current drivers for your card.
I did, but the software wont install drivers unless it "is plugged in", which it is.
Try moving to a different slot till you get the drivers downloaded. Then move it back to the one you want it in. Also you may consider rebooting system to see if it detects it. Try rebooting a couple of times.
No, i have run the drivers but they wont install until it detects it in the pci slot. i have rebooted many times
Depending on your os it may not allow you to use your drivers. Had that problem with win 8.1 but it should supply some form of drivers that work with it. At least basically. You may also try win update to see if it may supply some form of working drivers for your card. If your running windows that is.
I would would go to device manager and get and see if its has detects any wifi at all. Have you installed all the new drivers for your system . May also try a little program called driver booster made by Iobit. Is your Bios updated. Got to the mother board  maker.
LOL, apparently i had to use the cd drivers.................
