Ok so I am having a problem with my new pc. Sometimes when I turn it on it does not send the info to my screen. The fans come on, the lights in my keyboard and mouse come on, everything gets power but my screen does not get the info. This is only a problem from that was happening about once a week and I did not pay much attention because just restarting the computer usually fixed it. But right now i have restarted about 20 times and nothing is happening. The moniter and vga cable are basically brand new.
If someone could give me some information on what the problem could possibly be I would be very grateful.
Any advice is appreciated, Thank You.
return for refund while you can
which part? this was a custom build
you the builder, then your'e the support tech too.
we will need more info so list the build please?
here is mine as an example
ga-z77x-ud5h
3770k @ 4.49, 1.26volts
evga titan
16gig gskill 1866 @ 2000
corsair c70 vengance
corsair hx850
corsair h110 fans in push intake to create posive pressure (4 intake 1 exhaust)
seems to run as cool as when they were push exhaust
mushkin deluxe 240gb msata for games because port 5 is sata2
mushkin chronos dx 240 gb on port 1 for full sata3 windows 8 with startisback
That cpu voltage is a little low for that overclock. Have you tried increasing it?
wow, im having the same problem. i think it's the video drivers... i not sure tho.
