New pc (need help)
hi I just set up my new pc
specs as follow:-
rog hero vi hero -
gtx 770 classfied-
coolermaster1000w-
corsair DDR3 2133 MHz 8gbx2-
samsung sdd 256 gb pro -
i7 4770k using just stocker cooler now-
first time i plugged it in i got 2 long beeps 1 short beep and i got qcode 53-15----- after i tried clearing my cmos and a friend told me to try with only 1 slot of memory... after that i got no beep sounds but got qcode 15-21-36 , friend told me maybe memory not compatible -- I tired a old memory stick I had Mushkin XP3-12800 2gb Kit DDR3-1600 Nehalem I just plugged 1 in to see if it will work and I got also no beeps and I got only qcode 36-15.. ( i still got no onscreen display I tried connecting fro gpu motherboard and my gpu nothing, I see no lights flickering everything in the pc was running smoothly fans.gpu was spinning--- I plugged everything correctly double checked everything
If you look at your motherboard manual it will tell you what those beeps and codes mean.
35 - cpu post-memory intilization  and 15 pre-memory system agent initialization is started ( ye i dont get it )
Put all of your memory back in and allow it to attempt to fix itself, then press memtest and allow it about 30 seconds. It should try to reboot. If it does not, after pressing memtest, reboot anyway. My friend has an Asus motherboard, and for some reason, this fixes some of the memory issues.
the motherboard was doa , i contacted asus for a replacement
