A couple of days ago I built myself a pc for the first time and I thought I had done everything right. But when I got it all together and turned it on the computer flicked off then on and kept doing that. I later figured out that it was in dualbios mode so I switched it to single. The compute then stayed on but still would not post. Then I tried disconnecting everything except for the motherboard power and cpu power with one stick of ram. During all of that I reset the cmos many times.
Now I have no idea what to do. I have looked all over the internet for a solution but couldn't find one. If you have any idea what is wrong please tell me.
Here are the specs:
Motherboard: Gigabyte Z87X-UD5H socket 1150
CPU: Intel i7-4790k, 4 GHZ, 8MB Cache, LGA 1150
Power Supply: Corsair RM Series 650 Watt ATX/EPS 80PLUS Gold-Certified Power Supply - CP-9020054-NA RM650
Graphics card: EVGA GeForce GTX760 SuperClocked w/EVGA ACX Cooler 2GB GDDR5 256bit
RAM: Crucial Ballistix Tactical Tracer 16GB Kit (8GBx2) DDR3 1600 MT/s (PC3-12800) CL8 @1.5V UDIMM 240-Pin
