OK ive just finished my new budget pc build the spec is as follows
Amd a10-5800k cpu
asus radeon hd6670 1gb ddr5 gfx card (crossfired)
asrock a75 fm2 dgs motherboard
crucial ballistic sport 2x4gb 1333mhz ram
and maxtor 500gb hard drive
now my machine was running great untill my second graphics card came today , i installed it and set up crossfire and now when i click on a drop down menu/adress bar/login box , of any kind it will show a screencap of my screen in the size of the window the drop down box produces kind of like a display with in a display
also ive noticed even with my machine running crossfired cards, i still dont get any higher scores on any benchmark program i use??
please can someone shed some wisdom on this thank xzx
