New PC Build Help
Hey all! First time posting in here. I have been putting together an X99 build and have hit a bit of a snag as far as price goes. Was hoping to keep the price as low as possible, but have somehow gone over $2000. I have built one PC before but that was a few years back. I would mainly be using this for watching movies on the web (work related stuff), 3d modeling and rendering with Maya, light gaming, video editing and graphic work such as after effects, premiere, and photoshop. Any assistance would be greatly appreciated! Here is what i have so far. i have been building this through newegg.
  • Corsair Vengeance Series C70 Gunmetal Black Steel ATX Mid Tower Computer Case $129.99
  • ASUS X99-DELUXE LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $373.49 ( i liked this because of the onboard bluetooth and wifi capability.)
  • GIGABYTE GV-N980G1 GAMING-4GD GTX 980 4GB 256-Bit GDDR5 PCI Express 3.0 HDCP Ready SLI Support G-SYNC Support Video Card $629.99 (friend recommended this card to me)
  • CORSAIR HX Series HX1050 1050W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power $209.99
  • Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3 140W Desktop Processor BX80648I75820K $389.99
  • G.SKILL Ripjaws 4 series 16GB (4 x 4GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4-21300) Desktop Memory Model F4-2666C15Q-16GRR $259.99
  • CORSAIR Hydro Series H100i Extreme Performance Water/Liquid CPU Cooler. 240mm $89.99 (saw a bunch of builds online that use this. ive never done liquid cooling before)
  • SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) $135.99
Grand total $2422 after taxes and shipping.
Any assistance in lowering this would be great. I'd like to keep with the power as it seems like a great build, but I am open to changes if what I have is unnecessary.
What monitors are you running?  Honestly unless you want best of the best (or feel like you do) I wouldn't go x99 its way too high a premium for the performance (granted it is good though).  You could save a bit and since you say you're only doing light editing would go 4770k or even the i5 variant and save on a mb and ram.  Also unless you are running above 1080p monitors I wouldn't get a 980 even a 970 is a little overkill but with those 2 changes alone you'll save a couple hundred bucks, and really only notice a difference in render times.
Thanks for the tips. I will actually be doing light gaming. Most of my work will consist of video editing, graphic work and 3d animation related rendering and work. Monitors wise I actually don't have anything yet. Just a samsung TV currently, but was planning on buying at least 2 decent monitors to work on. I was mainly looking at x99 because of the cpu i picked. I liked that it was 6 cores and powerful, but I see what you mean with it being pretty premium. my last 2 builds were AMD so I am new to the intel world.was just kinda going off what I was seeing on youtube builds.
look at the build in my profile, its pretty powerful, i do gaming, photoshop, autocad and occasional video editing. its under $1500, i think it was something like 1200 or 1300 but i don't remember. You can also get one of xenons or 4930k, on x99 you are paying premium for mobo and ram( ddr3 16 120-140$ for good brand)
Thanks bogdan. What's the big diff between i5 and i7? Was thinking this build for something to last a long time without needing to upgrade anything. Will your build last?
X99 is still pretty new, and it carries a hefty price tag.  If you don't have >$2k, it's probably better to go with Intel's mainstream LGA1150 Z97 platform.
i5 vs i7 on Z97 is basically just hyperthreading, which helps in applications like 3D modeling, video rendering, and anything else that can take advantage of more threads.
What's your preferred budget?
my build should last for 3 maybe 4 years( my guess lol, but it when skylake cpu's come out (late 2015) they are going to be lga1500 so there will be some parts you could upgrade you need be), 4790k has hyperthreading and cost $330, 4690k is $230
