i've been saving up for a computer for a while now, i have $1500 AUD saved and i'm hoping to get $2000. i was wondering if you could give me some parts that i could get that would fit within that budget, I'm 14 and live in Australia and i think that being able to build a PC will be something helpful in the future. Also something that i wont need to tinker with too much as i am "too poor to buy cheap" as my uncle says, any advice for begginers like me and or some parts for the computer would be great
Wrong section mate, there is a PC Build section specifically for this subject. May be an idea to go here and post you query. https://teksyndicate.com/forum/build-pc
State what you are going to be using your pc for, do you need a monitor, os etc. Also any preferences towards any brands so forth.
