New motherboard issues
Just upgraded from an asrock b75-m to a MSI Z77A-G43 and now all my PC does is flick the fans a little any help would be nice thanks
What CPU do you have?
i5 3570K
Well, did you put the CPU in the right orientation, and if so, did you plug the EPS power cable plugged in?
Both I double checked
Remount the CPU, check for any crushed pins.
All pins appear to be fine
A short somewhere? Check the motherboard standoffs are in the right place and extra ones arent left to short out the board. As brennan said check the pins. A very noob mistake to do but shit happens.
Double check your ram dimms are inserted all the way in as well.
