Hey all, first post on the forums!
Anyways, I just upgraded my PC with a new case, motherboard, CPU, and graphics card. When I turned it on the first time, I could only get video output directly from the motherboard's VGA. Windows Startup Repair tried to repair for about half an hour before determining that it could not fix anything and that I should just turn off the computer. The next morning, I turned it on again, but I couldn't get any video output from the motherboard or the dedicated graphics card!
This leads me to my two questions:
1) How do I fix the video output problem?
2) Once the video output is fixed, what steps do I need to take to get Windows working again? The things that I recycled from my old PC are the PSU, two hard drives, the disk drive, and the RAM.
Motherboard: ASRock Z75 Pro3
Graphics card: ASUS GTX 660
OS: Windows 7
Thanks for any input you guys have!
It's some 550w 80 plus certified Antec.
Personally I'd make sure the PSU was working correctly (check the voltages on different pins, be careful!). Check all the components are fitted right e.g. gpu is all the way in. Also ask yourself is it possible you damaged the motherboard in the build (although if you did I would imagine it flat out wouldn't work at all). Also try all the different ports on the gpu if you can, I remember when I built my first computer it only worked out of one of the two DVI ports. Take out the gpu and try the integrated.
Also posting the bios settings could be helpful for others to see how to help you. I understand this is difficult with no visual display.
Also it isn't clear what the second question is asking, as you haven't stated anything else was wrong I assume once the video problem is fixed Windows will still be fine, and if not just reinstall it.
I had tested both DVI ports when I first had the problem and both didn't work, but I tried it again this time and it worked! So now the video output problem is solved. I'm in the bios right now, but I'm pretty new to this kind of stuff so what exactly should i post?
About the second question: I was under the impression that with so much new hardware, Windows probably wouldn't even recognize it as the same machine, so I was expecting some kind of process to make it recognize it again, maybe?
Please, I'm just sitting here with a computer that can't boot into Windows and I don't know what to do.
When you do such a large upgrade, I recommend a clean windows install. Backup what you need and re-install windows. You will also need to install all the drivers for your motherboard and GPU. Make sure you get the most updated drivers from the manufacturer's website.
Well in bios have you made sure to set the correct boot drive, being all your drives probably have data on them it might look to a non boot drive and just say no boot disk detected, or if your boot drive has some issues like a corrupt mbr then it might go to a black screen and give you either an error or will just boot loop. Have you had your pc do any of these?
I'd also doublecheck the BIOS to see if there's any kind of setting where you have to set the default GPU, I know motherboards in the past i've worked on had this odd issue.
So if I put in the Windows 7 disk it should automatically give me the option to clean install?
The times I've turned it on, it initially started booting into Windows before flashing a blue screen and then going into a black screen that gave me the option to either restart the computer or start an automatic system repair.
Btw, if I put in the Windows 7 disc at this screen, will it let me do a clean install?
Well if it seems to try and boot into windows then there is probably a driver issue or corrupt file and sticking the disk in a doing a system repair may help or i think it's f8 and it will give you a screen to boot into safe mode try that and see if it will boot in safe mode
Booting in safe mode also ends up with a flicker of blue screen then an option to restart computer or try System Repair.
I'm going to try the clean Windows install thing, but I need to move some of my old files onto this laptop I've been posting from somehow. Any idea how I can do that? Also I have two hard drives of the same brand, so I have no idea which one has Windows installed on.
Also, I've tried booting from both hard drives and they have the exact same results.
Enter your bios.
Move your DvD drive as your main boot source
Insert Win7 DVD
Start the computer. If it doesn't boot to your Windows 7 disc, then look for a boot menu during bootup, select Dvd, and complete the install. Whenever you install windows 7, it'll wipe the whole disc unless you bother with partitions and stuff.
So does that mean if I "bother with partitions" I can do a clean install without losing any files?
Theoretically, yes.
But with the problems you have right now, I would try to back it up to some other hard drive not connected to the computer, and transfer only the vital files you need.
I just found out about the Windows.old folder that is created when you do a clean install. Is everything from my old hard drive going to be there or what?
Not usually, i think it only keeps stuff that was in your my folders like my documents and my pictures
Hmm, okay. I don't think there was really anything that I wanted to keep anyways but documents and pictures.
Thanks for all the quick responses, guys. I'm waiting on a SATA power cable for my disk drive right now but I doubt reinstalling Windows won't work.
