So I've just replaced my Msi 970-g46 with an Asus Sabertooth 990fx and everything seemed to go fine. I haven't changed anything else but now I'm having issues with Windows. As if at random, windows explorer now stops responding. I can still play games for hours at a time, but it will be whenever I'm doing stupid little things like switching tabs in Chrome or going from the Steam Store to my Steam Library. Suddenly my computer freezes up, and even Ctrl+alt+del takes 10 to 15 seconds to "fix" it. I say "fix" because I don't actually know if doing that is helping, or that's just how long it normally takes to fix itself anyway. I'm on Windows 8.1 and have NOT OC'd yet. Still running at stock clocks, even though I bought this motherboard to OC. Help is appreciated, thanks!
Did you reinstall windows? If you change mobos it's usually a good idea to at the very least remove all of the old mobo drivers and install the new ones but I find it's best to re-install windows when changing motherboards, it avoids issues like this most of the time and if your C:\ Drive is for the OS and programs and you use a second partition/HDD for storage I find it can be a little faster.
you could also try sysprep, remove all drivers, reboot and then install the newest drivers from te asus site. But i personaly allways prefer a fresh install.
Thanks, guys! I'll be sure to install windows again asap.
