New Headset Help
Hi guys before anybody say's to just buy a pair of headphones and then buy a seperate mic, I do NOT have enough space on my desk to accomodate a standalone microphone so an all in one Headset is a must.
I've recently been looking at headphones such as the Razer Kraken Pros and the Corsair Vengeance 2000s, and am not sure what to get. I may consider buying a dedicated sound card later on, not sure if this helps with the choice, my current headset is the Turtle Beach X12s (I mainly bought them because I used the use my Xbox more than my PC but thats all changed). Any other different headset recommendations would be nice!
Thanks again guys :)
I do recommend the corsair vengeance series headsets,
i got a 1500 myself, its cheap its super confortable and 5.1 of wich is very nice.
also it has a build in soundcard (that does get warm after a while) but no worries.
the mic is crystal clear and the foam is awesome,
(i've been using it for over a year now and still happy)
I havent heard such good things about the corsair headsets as you are describing. I will recommend, as I always do, the astro a40. Tried, true, and tested, they are always one of the best performing all around. If you dont like them, maybe the Sennheiser PC360's would be better.
the only bad thing i could find was the freaking long cable,
everything else is just great.
i havent got such a good headset in years.
but i-am sure there are better without a doubt but for the prize this is probaly the best bang for the bug.
