**new GPU** need help!
I'm looking to get some new parts and i recently posted in the CPU category and they suggested a new GPU not CPU. I mainly play BF4 and ArmA 2&3. In both ArmA's I play online mods such as DayZ and Wasteland and on both I get 17-25FPS. On BF4 im getting anywhere form 20-60. the numbers aren't steady and drastically change every second. I thought a new CPU would help but apparently a new GPU would be best..
Here are my specs:
CPU: AMD Phenom X4 9750 (2.4GHz)
Motherboard: Asus M4A785-M
GPU: AMD Radeon HD 7770
RAM: 8GB
If there is anything else you'd like to know just ask.
I upgraded my GPU last year and really don't want to throw that one out for a new one, but it looks like I might not have a choice. I was thinking of getting just a new CPU, and FX-8350, but if a new GPU would be better than that's what ill get. my question is what should i upgrade? Just a new GPU? Or a good combo of a new motherboard, CPU and GPU? any suggestions would help. My budget is around $400 but i will pay $500 if necessary!
Thanks!
Here's mobo, cpu, gpu combo for 490$ that will max out bf4 and will run it even better when mantle is out.
http://pcpartpicker.com/p/1Zlei
Can you please tell us the exact model of your PSU to see if it has what it takes to power that 270x.
Thanks for the suggestion. Just broke the CPU today haha... I believe its a 680W ATX... I'm not %100 sure but if that sounds right then let me know.
AMD FX8320 or FX8350 8 core with asrock extreme 3 board, 4+1 powerphase and low quality vrm´s and chokes is not realy the best combo.
Better would be  a FX8320 with Asus M5A99FX pro R2.0 board, and if you can stretch your budget just a tiny littlebit a GTX760 or Radeon 7950 would be a better choice. if not a R9-270X is still a good choice.
How much better would BF4 perform with a 7950 over an R9-270X? Honestly if i can run BF4 without dropping below 40-30FPS on high im fine with that!
Will my PSU handle it? 650W?
http://www.superbiiz.com/detail.php?name=MB-M5A99E2&c=CJ I'm sorry this motherboard is better it has digi vrm nice heatsinks and plenty of overclocking headroom, based on what you said you should be happy with a 270x Your psu should handle it fine. Only thing is you can find a 7950 at a damn good price if you know where to look and black friday is coming up the sales will be killer soon.
Looking to find a good deal on boxing day!
