New cooler for Clevo W550SU
Hello
The CPU cooler in my Clevo W550SU is extremely noise and i would like to replace it with something different. Do any of you know where i can buy something different for it? I cant control the fan with fan controller programs nor is there a BIOS option.
Suggestions?
Thanks.
I think your options would be
  • Replace it with a new OEM fan (would most likely sound the same)
  • Somehow slow it down (would require soldering and stuffing)
  • Get a cooling pad with quieter fans to maybe cool of the laptop so the integrated one doesn't need to spin as fast.
Alternatively, it could just need some cleaning if it's progressively been getting worse over time.
