hi,
i'm on the way to build a new gaming pc, and the parts are the next ones:
http://pcpartpicker.com/p/3xagB
i already have the videocard because my case with the other parts was stolen with the moving, and i'm thinking of changing the mobo for a asus rog impact.
What do you think, what can i change?
i was thinking the same, but at the moment i prefer space than velocity
Are you going to be overclocking?
If you are, you will need a motherboard with a Z87 chipset.
If you are not, that K in the processor is useless. Grab a i5-4670 or a Xeon 1230v3
Fancy RAM. If you want to save some money, grab some cheaper RAM. If you're going for the looks, then that's up to you.
I would also recommend a SSD for boot or caching.
yes i'll be overclocking thats why the seidon, the asus H87i-plus just got an update for let the mobo be able to oc, but i change it.
i don't need a very fast booting pc, thats why i'm not ussing an ssd, how about now?
http://pcpartpicker.com/p/3xhqZ
later this year i'll be buying another 2tb hdd
a little, i had a bitfenix prodigy and the space that it left was perfect, but the prodigy was on the ground, because on the desck...well let's say that i almost drop it, but this one will be on the desk because the space needed is just a little.
You don't need that much of a motherboard. The airflow in the Hadron isn't really optimal for massive overclocking. You'd be fine with a MSI Z87I AC Gaming or Gigabyte Z87 wifi motherboard.
well in the begging my plan was OC to 4.3, and with the liquid cooling won't be a problem, but i'll se if i can find the MSI gaming AC mobo, because i'm not on the US, i'm from mexico and here is a little dificult to find some mobos or other parts :S, and the prices are really high, the asus rog impact here is at $3500 mexican pesos, some thing like $335 USD, i'll try to find the MSI and check the gigabyte because that one i saw it the other day
