So i have just built my pc with everything apart from my GPU that gets here next month, so i turned it on and it beeped 3 times, looked it up and found my ram was not in all the way. sorted that and now everything turns of as it did but no beeps at all and nothing comes up on my screen
my specs are:
Athlon II x4 750k
4gb of Kingston 1600Mhz ram
a corsair cx 450watt 80+ power supply
some random cd drive and thats pretty much it, i have made sure everything is plugged in and plugged in all the way and it still does nothing but spin the fans and flash some lights
any ideas?
That CPU has no graphics so you need dedicated GPU. You didn't list one that's why i ask also what MOBO do you have.
My GPU that gets here next month is a radeon 7770 GHz edition and my mother board is an MSI FM2-A75MA-P33
Well without a GPU installed your not going to get any picture.
Guess you will be using it next mouth. The mother board has video ports only because it supports APU's this does not mean every processor that works with the FM2 socket has a GPU on the die.
Yep. This ^
Only the AMD A series has the integrated graphics. The Athlon II X4 you have doesn't have useable graphics on it.
Ahh thank you :) i didnt know
