hello i could really use some help on building a new pc i have around £700 but could go a little over i do need an opperating system (preferably windows 7 64bit) i had my heart set on an asus sabertooth 990fx motherboard and a amd fx 8350 but if you guys can come up with something good then im all ears. this is going to be my first build so im really looking forward to it the games i would like to play are mainly wow d3 deadspace crysis ect and i would like to have some good fps anyhelp would be much apreicated
Just be a second..
okay mate cheers
Well for windows you can download it totally regally.... Otherwise you're going to have to knock your graphics down to a 7850, get a lower wattage power supply, a worse case or a worse hard drive but this is a pretty solid build to be honest.
http://uk.pcpartpicker.com/p/IZug
If you need a way to get windows 7 then just ask me :)
Build with win 7 and worse graphics:
http://uk.pcpartpicker.com/p/IZxH
Build with win 7 and worse everything else...:
http://uk.pcpartpicker.com/p/IZCz
cheers mate this was my original build i was planning on what do you think :) http://orders.ebuyer.com/customer/shopping/index.html?action=c2hvd2NhcnQ%3D&stid=1
That links me to an Asus Padfone 2...
sorry mate
here are the specs the old fashioned way ;p
cpu
AMD FX-8350 4GHz Socket AM3+ 16MB Cache Retail Boxed Processor
cpu cooler
Arctic Cooling Freezer 7 Pro rev 2 Socket 775, 1156, 1155, 1366, AM2, AM3 Heatpipe CPU Cooler
motherboard
ASUS Sabertooth 990FX R2.0 Socket AM3+ 8 Channel Audio ATX Motherboard
ram
G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V
gpu
hard drive
WD 1TB Blue Desktop Drive 3.5" SATA-III 7200RPM 64MB
case and fans
Coolermaster Elite 430 All Black Case With Elite 500W PSU
Casecom 120mm Blue LED Fan - 4pin Molex Connection
software
Microsoft Windows 7 Home Premium w/SP1
total price is £710 pounds is this good as i would like to maybe venture along the overclocking line at somepoint :)
I would advise you get the kingston beast I put in as it is cheaper and you're getting faster, higher quality Ram.
Everything else seems perfect however the powersupply is something you may regret as it is not 80+ nor has it got a single 12V rail but nothing else would fit in your budget so it's up to you.
okay mate i will put the kingston in and i may be able to stretch it out mate i could put this case in which is a bit better quality and comes with a better power supply
CM Storm Enforcer Case with Coolermaster 650W GX PSU i will have to ask my dad but if i could would that be a good pc that i could do a nice overclock and fun games like dead space wow d3 in high settings and still get around the 70-80 fps mark :)
http://uk.pcpartpicker.com/p/J0Cp
Yeah, should be good enough.
You should be able to get your CPU proabably to 4.8ghz quite easy and 100-150 mhz overclock on the graphics card easily.
Nope... No...
Go with this guys...
Much better and maybe get a CPU cooler later down the line?
sweet thats fine if i needed to at anypoint would it be possible to change the cpu fan? if not then theres no worry
hmm that does look good im just not overly keen on the case and if i went with mine i would be able maybe get another 7850 in a month or two and run it in crosfire ??
Any case is fine really. Get the one you linked to me just with out the powersupply and it should be less than the bitfenix one I just linked that because I thought it was decent looking.
As for crossfire you are much better off with a 7870 than a 7850. The difference is probably like 30% maybe more and then with crossfire you have the possibility of driver issues and stuff like that but it's up to you.
okay mate thats fine i really apriciate your help to both of you guys i think i might order the stuff within the next couple of days so it gives me a little bit of time to think about it and i will update you when ive built it if you like :)
Please do :)
