Don't buy the A10 if you're not going to use the intergrated graphics. I'd rather buy something like the 6300. That way the system will perform better and you'll have a lot more upgrading options in the future.
I'll try to put together a system. Could you tell me what your budget is?
Also what are you going to use the computer for? Is it only gaming or are you going to record your gaming sessions? If so it would probably be a better idea to go with a Nvidia GPU, reason being that the CUDA cores help a lot in editing and rendering.
