New Z490 , i5 , Windows 10 Pro - Can not see Motherboard Fan’s in Open hardware monitor or Speedfan or HW-Monitor can see CPU fans in Afterburner with no issues but not any Motherboard fan therefore I cant adjust the speed and the heat is really bad 4 cards running on workstation. Thanks For all your help have tried all setting in bios Nothing ???
With mainboard is this?
Try setting the fans on turbo in bios, I never bother with pwm
Also maybe the fans simply don’t spin any faster?
Change it from standard to turbo, save changes and see if the rpm changes speed
MSI Z490 Gaming Plus
Thanks I will try that now !
Comb through the BIOS menu [+ update if applicable], in case that sub menu exist for fan curve / settings, lodged in somewhere deep and obscure… see picture, for how it would look, off an MSi board
Thanks that what I needed !
