Okay, now why should I not go with an Intel CPU? Well, the equivalent would be the Core i7. I don't see the need to spend another $100-200 on a CPU when the FX-8350 has enough power. Looking for opinions and criticism here. This isn't my first build, but it is the first new build for myself I've done in a long time.
well, you want a beefier psu for the 8350. since your going with custom WC, heat isn't as much of a problem. get the sapphire 7970, and for the mobo, get the asrock fatal1ty proffessional. asus is kinda lacking with their amd mobos (ut i'll re-evaluate anyways). for ram, just go with g.skill ares or ripjaws ddr3 1600. hdd- WD black.
also, gigabyte mobo's are nice. i like them. especialy since they pulled their head out there ass and stopped with the crap tastit blue color scheme. also, 500w will be good for almost any setup you make that doesnt have 2 gpu's
