New build from Cyber Power
I just configured this at cyberpower.com. Not sure about the mobo or the ram. I don't plan to oc or sli. $1268 out the door.
GAMER SCORPIUS 9000 (NO MONITOR)
$1,163.00 × QtyTotal: $1,163.00
Configuration
*BASE_PRICE: [+1100]
CASE: Cooler Master HAF 912 Mid-Tower
CD: LG 12X Internal Blu-ray Drive & DVDRW, 3D Playback Combo
CPU: AMD FX-8350
Heatsink: CoolerMaster Hyper 212 Evo
SDD: 120 GB Kingston HyperX 3K SATA-III 6.0Gb/s
HDD: 500GB Western Digital Caviar Black
KEYBOARD1: AZZA Multimedia USB Gaming Keyboard
MEMORY: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory
MOTHERBOARD: * [CrossFireX] GIGABYTE GA-970A-DS3P AMD 970 Socket AM3+ ATX
MOUSE1: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
OS: Microsoft® Windows 8 (64-bit Edition)
OVERCLOCK: No Overclocking
POWERSUPPLY: 750 Watts - EVGA SuperNOVA NEX750B 80 Plus Bronze modular
RUSH: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
VIDEO: NVIDIA GeForce GTX 760 2GB
PRICE: (+1163)
No, don't use Cyberpower
what's your budget, I'll give you a custom list that's much faster or way cheaper and reliable for the same speed
That list is really hard to read and there are no prices for the individual items. The mobo supports the 8350 and should be fine since you wont oc, but what sticks out is that your psu is totally overdimensioned, you could use 2 high end cards with that or three 760s.
about 975  before taxes without peripherals if you buy the parts from different vendors  http://pcpartpicker.com/p/1AiTM (only 500w psu but better mobo and 1 tb hdd)
Do they assemble the pc, install windows and give you warrenty for that price? If it is so the markup is reasonable.
Edited OP so not so anyone other than a robot can understand it
What is wrong with Cyber Power. They are local so that I can pick up the computer saving a shipping cost. I am a bit of a novice when it comes to computer building. I like the idea of having support in case something goes wrong. My 2 previous computers were from PC Club. Both had to have the mobo replaced within weeks. I am still using the second one. If I were to build myself I would go through Micro Center for most of the parts. Again they are local.
Cyber Power builds custom gaming computers. They get descent reviews. They are local.
extremely overpriced the mobo is junk the hdd is small the keyboard is meh you do not need a 750w psu and for $1200 you can have so much more for your money.
Dont but a pre build. Aparantly cyber powers build quality is really bad, go with a custom pc that other people have suggested
Cyber power almost always uses Reference Graphics cards (Meaning you can get better versions of them) and they usually take a big cut somewhere around $200. If you really want to get a custom "pre-built" look at NCIX from what I hear they only add a $50 charge for building it.
However as most other people on TS will say, build it yourself. its a great experience and you save money doing it. (Even though your saving shipping from cyberpower you'd still be better off paying ~$50 for shipping as the charge for getting it built is somewhere around $200)
http://pcpartpicker.com/p/1Ak1v
Sure, a 7950 isn't as good as some others, but it is a great performer overall.
better and a 100 bucks cheaper, build it yourself its super easy its like legos,
https://www.youtube.com/watch?v=W4Js2A1qdB8
Or you could build it yourself and buy better components with what you save. If it's the warranty you want each component has a warranty with the manufacturer.
http://pcpartpicker.com/user/jruelas11/saved/2krQ
http://pcpartpicker.com/user/Killerfrenzy96/saved/2ktb
