New build. And i need a psu
So this is my first time full on building a pc. i have, in the past, tweaked an already existing pc but i have never started from scratch. Now i already have all the peripherals, i also have a HDD, RAM, and a disc drive(i already have it so i might as well use it.)
Here is the computer i had in mind.
-HAF 912, For a case
-MSI 970A-G46 motherboard.
-AMD FX-6300 3.5 GHZ
-1.5 TB HDD
-8 Gigs of DDR3 1600
-AMD R9 290 (most likely from ASUS)
Now here is where i hit a snag, as you can tell by my recycling of parts i don't have all of the money in the world, and most of it is going into the R9. Now i am buying some parts of Newegg.ca and some off of Amazon.ca.
My question to the masses is what should i get for a PSU, under 100 Canadian would be nice but it is not required.
Thanks
http://holynerdvana.blogspot.com/2013/11/litecoin-mining-with-r9-290-and-r9-290x.html according some guy doing a mining rig, (I know, not the greatest source), the 290 might pull 330w at max load. I believe the 6300 pulls roughly 100w, so you're probably looking at a 500w psu to be safe. Here's a SeaSonic semi-modular 620w for less than 100 US. Not sure about the amount in Canadian dollars. http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
That is perfect thank you. it is 99.99 on newegg.ca and modular would be nice to have for airflow reasons alone.
I have the same psu and it runs very quiet :D. I'm glad you're happy.
