[NEW BUILD] £400 build
So, I'm trying to get a cousin of mine over to the PC side, his budget is £400.
I've had a few ideas, but they always end up being over-budget.
The budget doesn't include:
  • Monitor
  • Mouse/Keyboard
  • Case
Also, he already has an 120GB SSD (from his laptop, which will then be going back to the HDD it came with), so don't include one of those.
I'd prefer the GPU to be a R9 270X.
I'd prefer the seller to be Amazon, but feel free to post links to sites that you've had a great experience with (I've dealt with too many crappy retailers).
Thanks you all very much in advance, I hope you are better at budgeting than I was. :)
http://uk.pcpartpicker.com/p/2zwJA
CPU: AMD FX-6300 3.5GHz 6-Core Processor (£82.49 @ Ebuyer)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard (£64.99 @ Amazon UK)
Memory: Kingston XMP Blu Red Series 8GB (2 x 4GB) DDR3-1600 Memory (£62.99 @ Ebuyer)
Video Card: Gigabyte Radeon HD 7870 2GB Video Card (£136.34 @ CCL Computers) (A 7870 is a 270x)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (£47.12 @ CCL Computers)
Total: £393.93
(ignore the Potential Issues/Incompatibilities at the bottem of the page all R.2.0 vershons of asus mobo's are uptodate for all new cpu's)
Same CPU/Motherboard as I had previously chose.
I was thinking of the 270/X over the 7870 because of the Mantle support (7870 doesn't support Mantle, does it?), then again, who knows how many games will utilise it?
Thanks. I'll definitely keep your recommendations in mind.
All AMD cards starting from the HD7450 and up are GCN architecture all GCN cards support mantle.
Got it. Thanks.
cooperman's build should handle your stuff nicely
