New Build, $1k (£600), Tips & Advice Would Be Great!
Hi guys, first post with a new account. So recently I started Uni (College in US) and I would like to spend about £600 on a gaming rig, havn't built one since I was about 12 and tech has changed soooo much. I will be using it almost exclusively for gaming and already have Win 7 OS. Just wanted to hear if what the feeling was towards the parts and if anyone had any suggestions for better parts? Thanks :) Just bare in mind I need UK suppliers.
CPU: AMD FX-4350 4.2GHz Quad-Core Processor (£89.99 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£23.98 @ Scan.co.uk)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard (£59.00 @ Amazon UK)
Memory: A-Data XPG Gaming Series v2.0 8GB (2 x 4GB) DDR3-1866 Memory (£41.40 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£47.84 @ CCL Computers)
Video Card: MSI GeForce GTX 680 2GB Video Card (£239.62 @ Scan.co.uk)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case (£38.64 @ Scan.co.uk)
Power Supply: Corsair CX 500W 80 PLUS Bronze Certified ATX12V Power Supply (£50.12 @ Amazon UK)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£12.98 @ Novatech)
Total: £603.57 or ~$978
I would get a XFX 550w powersupply
I would also get a FX 6300 or a FX 8320 cpu
make sure you get this 680
I looked into a Hex/Oct core cpu, but most games arn't optimised for them right? Am I wrong to assume that there wouldn't be much of a performance increase, also is there a youtube vid you would suggest explaining this? Also thanks for the PSU recommendation :)
Amd cpu's are weaker per core that's why the Fx-8350 (8-core) competes with the i5 3570k (4 core).
that was true but the new games can use 6-8 cores now unless you are getting an i5 get the fx6300/8320
New games comeing out now that will take adavtage of 8 core cpu's (bf4 /crysis 3 are prime examples)
The FX8320 is only around £30 more than the fx 4xxx cpu's (you can find them cheaper i picked one up in a sale for £90!)
Ah right, ill bump the cpu up to an 8320 then, thanks.
I went 0.63 over.  Oops.
http://uk.pcpartpicker.com/p/1K9nX
CPU: AMD FX-8350 4.0GHz 8-Core Processor. More cores, and higher than the 8320.
MOBO: Asus M5A97 R2.0 ATX AM3+ Motherboard.  Had everything I was looking for.
HDD: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive.  Never had a problem with Hitachi HDDs, and has a decent amount of space.
GPU: MSI Radeon HD 7970 3GB Video Card.  Comparable to the GTX 770, which is very similar to the 680.  A lot cheaper, also.
CASE: NZXT Source 210 Elite (White) ATX Mid Tower Case.  Same one as OP.
PSU: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply.  Great PSU.  Rebranded Seasonic.
OD: LG GH24NS95 DVD/CD Writer.  Simple OD drive.
How exactly has a fx8350 got more cores than a fx8320? and puting one on a 4+2 power phase 970 mobo is a waste of potential for a power hungery cpu.
And hitachi deathstar!!!! NO NO dont buy one of those!
I was referring to the OP's first post.
Hitachis have worked for me over the years.  I assume they haven't for you, and hence why you recommended against them.
Maybe you haven't heard the term 'hitachi deathstar' before, hitachi where voted in to the top 20 worst computer components of all time.
As a computer builder and systems engineer for the past 20 years i can tell you now you are siting on ticking time bombs useing them.
Allso
Change out the processor for a FX8320 or a FX8350 And change the GPU for a GTX 670 FTW EDITION :D (Just what I would do)
I shall follow your word and never buy any more Hitachis, as your experience surpasses mine.
I will go back to my little lair and continue to study :P.
Thanks guys will be ordering the new parts list soon :)
CPU: AMD FX-8320 3.5GHz 8-Core Processor (£109.19 @ Aria PC)
Video Card: Asus Radeon HD 7970 3GB Video Card (£227.75 @ Scan.co.uk)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£48.96 @ CCL Computers)
Total: £609.74
