Hey everyone;
I know i had topic about this a long time ago, but its burried somewhere.
Anyway, as the title says, im looking for new monitor. i had some money for christmas, and i finaly decide to buy a monitor.
Now the difficult part is that viewing angles are very important for me, since ive got one bad eye. i want a good screen, so i´m looking for a IPS and 27 inch for allround gaming etc...
unfortunatly i cannot afford a highress 1440p screen, so im looking for a good 27inch 1920 x 1080p screen. i know those korean highres are cheap, but im from the Netherlands, so thats no option for me!
My budget is arround €300.
i was basicly looking at 2 screens.
- LG IPS277L-BN
- LG IPS27EA73 LM-P
Now i also found a PHILIPS Brilliance Gioco 278G4DHSD monitor, this is an 27 inch ips 3D monitor with ambi-light, 7MS response time... does anyone has any experiance with 3D monitors?
If some one has better recommendations, they are also welcome.
Thanks.
I would go with the LG as I know they make a solid monitor I am not really sure about Philips though I have never seen any of their monitors or TV's in person.
I think you should save up a little more and get a 1440p monitor! Best option for you, if you want 27" and an IPS panel.
i found a clip from the philips ambi glow. it looks cool but i dont know if its good for gaming or not.. its a 3d monitor using an AH-ips panel, and 7 ms response time.
http://www.youtube.com/watch?v=uGf85pP1d4I
I actually really like the glow behind the monitor I have never seen that before.
You can buy the lighting separately, if you want that for any given monitor
yeah i know that but this monitor cost only €298 euro. thats why it had my interessts
Well, I was having a look, and I like this LG that you have chosen:
http://de.pcpartpicker.com/part/lg-monitor-ips277lbn
It is cheaper and I like the fact that it doesn't have a bezel around the screen. Looks quite neat. And that might look good with some back lighting.
thanks yest that LG ips is realy decent there is a bazel by the way,
http://www.youtube.com/watch?v=A4P3VmDSP3w
tomorrow i go to a media shop where they hopefully have both screens. the philips has also an LG AH-ips panel inside, the only thing that the philips has is that ambi back light 3D usb 3.0 and some gaming setting feutures, and an overdrive feuture.
Well i went to the shop today and unfortunatly i ran into bad luck they did not had the philips gioco nor did they had an LG ips277L-BN. so that was realy bad luck. But what i did, i just ordered the Philips Gioco, because this monitor has a better LG-AH-ips panel inside. then the LG-277L-bn they had the 23 inch version LG IPS23EA73, but the colors where dissapointing,
Tommorow the monitor will be deliverd. im very excited how Trine 2 will gonne look like on this ambi glow screen. ☺
