Build a PC Forum I need your help, so I am planning on building a small form factor gaming pc. I am partial to the gtx 770 but am open to suggestions. I do not play MMO's and would like to run almost any other popular game on a 1920x1080 Monitor on ultra at 40+ fps. My absolute max for this pc is $1500, but I would prefer to keep it around 1400 USD (not including peripherals). I am planning to over clock a little bit, not too heavy though. I am also planning on sticking with air cooling.
Here is my parts list (There is link at the bottom to PC Part Picker):
CPU: Intel i5-4670k
-- I think this is pretty much set in stone. I am open to suggestions, but I like this CPU.
GPU: Galaxy GeForce GTX 770 2GB
-- I like the GTX 770 and I picked this aftermarket card because it looks sexy in white (Yes I realize you can get other cards like the Asus gtx 770 for cheaper) Again I am open to suggestions, but I think this card will suit my needs well.
PSU: Corsair Gaming Series 700 Watt
-- I think this will suit my needs just fine
RAM: Corsair Vengeance 16 GB
-- I want 16gb 1600mhz ram and I you suggest other ram like crucial ballistix, please explain why you chose it over the vengeance.
CPU Cooler: Phanteks U-Type Dual Tower Heat-Sink PH-TC12DX Black
-- I love the look and performance of this CPU cooler, but if there is a thinner, high quality case available I will change it to fit the case.
Motherboard: Z87 LGA 1150 mATX motherboard
-- I am not sure about this choice, if you have a better option please suggest it.
Case: Fractal Design Arc Mini
-- I am currently using this case because it looks sexy. I would like a smaller case for easier travel though, and would like recommendations as to high quality small and portable cases. I am willing to spend more money on the case if it means better portability and quality. I also want my case to have a window so I can admire my work :)
HDD: WD Blue 1 TB 7200 RPM
SSD: Samsung 840 Pro Series 128GB
Case Fans: Fractal Design Silent Series R2 Fans to match the case -- if I change cases i will likely change fans
PC Parts Picker Link: http://pcpartpicker.com/p/26iD6
As I said I am looking for a case smaller than the arc mini, but still high quality case (hopefully just as sexy as the Fractal Design Cases). I am change CPU cooler and gnu if it will mean a smaller case for better portability. I also don't know about the motherboard so some advice on that would be great. Any advice is appreciated, thanks in advance for your help!
