New 1070 won't fire up my monitor [solved]
I have a new 1070 you and when I replaced the old 770 nothing happens. When I start the computer I don't even get any emblems of the motherboard on the screen. What should I do?
Troubleshoot in this order:
Check if the card is 100% seated and check the psu connections then try again if that doesn't work try a different port on the card, if that does not work, update your motherboard bios to the newest revision. If that doesn't work it's likely a dud.
Ram wasn't in all the way so nothing would fire up! Lol but thank you
Had not considered that since you said it worked before lol. Well glad you figured it out
crisis averted !
Updated title to avoid future confusion
