NetworkManager bridge over bond on 25gbps links - how slow?
Hi guys.
I wonder if anybody here could share, having the same/similar setup, networks speeds.
I have Mellanox MT27710 Family [ConnectX-4 Lx] dual-port - one NIC in each box - tree boxes which are all directly connected to each other.
Using NetworkManager I use: bond connection (two ports on Mellanox NIC) in mode=broadcast for bond, then I enslave such a bond connection to a bridge connection.
When I iperf3 such a “directly” connected network I only get only ~7 Gbits/sec and.. these are 25 Gbits/sec links, each port on Mellanox is 25 Gbits/sec.
Unfortunately I cannot right now strip this setup down to “regular” Ethernet connections, similarly directly connected - that would, that should tell me if a culprit might be my Centos’ network stack which “fails” in this bond |& bridge scenario or maybe… it’s my configuration somewhere, perhaps some other limitations in my hardware.
It’d be great to have your thoughts and even better, your experience/findings shared.
many thanks, L.
