Networking & Systems Grad looking at switching to Linux
Cat sat. Dog barked.
Different distros tend to use different network management tools. But most of them will use NetworkManager. They should run KVM the same, barring any issues with non-sane defaults depending on the distro; kvm is kvm. If most of your experience is with CentOS, I would suggest fedora instead of those as it will be more familiar; that and it’s a very good distro.
Well the distro doesn’t matter all that much, they’re basically just the same with different package release cycles.
Manjaro is Arch, so it’s rolling and bleeding edge.
The rest are all Ubuntu so no huge differences there.
Virtualizations hsould be the same across the board.
Try out Fedora, it’s in the rpm family you’re most likely faniliar with, and also, yes it is stable as in it doesn’t break.
But if you want stable as in ‘doesn’t change’, well, maybe look at rhel or back at centos.
They are ancient as far as package management goes tho.
