Just modernizing the house, been thinking of doings this for the past year or 2.
I'm looking to build a surveillance system and add a couple of Ethernet port to a few of areas in the house next month, right now I'm just doing the ports and then the cameras will come later.
This is what I'm thinking of ordering.
Grandmax CAT6 Shielded 1000ft : http://amzn.to/1OXf63o
And for the switch I'm looking at these.
For the runs in the wall
Cable Matters Rackmount/Wallmount 24-Port Cat6a Shielded RJ45 Patch Panel : http://amzn.to/1Ve2OZm
Then for the switch
NETGEAR ProSAFE GS116NA 16-Port Gigabit Ethernet Switch : http://amzn.to/1Fmwo88
or
NETGEAR ProSAFE GS116E 16-Port Gigabit Desktop Plus Switch : http://amzn.to/1KzRiPU
Don't know if the Plus will make a real difference.
Everything's going to be put in here on the wall. Maybe. Still don't know if I want it on the floor or out of the way.
6U Wall Mount Rack Enclosure : http://amzn.to/1VehdVy
Going to order the other tools needed like the puncher, crimper, face plates, Etc... And for the cameras I was going to order some of these. 3-7. Depends on how big of a range I get. Was also thinking of getting some dome cams for inside the house, but still on the fence.
USG 2.4MP 1080P HD-IP PoE Network Bullet Security Camera : http://amzn.to/1L1nKMz
And the POE. May have to get one at a higher watt.
WS-POE-8-48v60w : http://amzn.to/1FEpP0u
Then I'm going to have to setup a parallel network to run my IP cameras, that'll be fun, no really.
And last but not least the NAS, maybe something similar to what Logan built for his subterfuge, a little more lower spec, Or the Thecus N5810 Pro that Wendell did a review of, maybe both, lol.
But really going to need to build another NAS just for my media, or is it okay to keep my surveillance video on the same system that I'm going to stream videos from and backup my system to? Probably not. Just asking.
Tell me if this sounds good or not, I want to get everyone's opinion on this, maybe even Logan, Wendell, and Qain.
I'm not above begging. PPPllleeeaaassseee!!!
