Hello all,
How do I get the network icon to show on the tool bar on the bottom right? I have a healthy network connection but the icon that normally shows a wifi/ethernet/globe is missing. It is not under the up arrow/hidden either.
Thank you!
Hello all,
Thank you!
Right click
Taskbar settings
scroll down and in the “Notification area” click Turn system icons on or off
enable Network.
This is also the area you can turn off the annoying action center icon.
I figured it out. Took little digging but I got it! Thank you!
