I use a random number generator with punctuation and other characters minus ascii. Password is 27 characters long.
I figured this was long enough... am i wrong?
There are passwords for the wifi and the router management
Both need to be strong.
Yep, I know. And both have a separate password.
Do you change both the router password and wifi when you make changes?
Im assuming you have tried changing the SSID and also making it not visible...maybe one that says "I know what you are doing"
I didn't used to, but since I started this topic I have been. I swear my notepad on my desk is gonna run out.
can you post a screenshot of exactly what you are looking at to determine the data usage?
also make sure that this netgear by default does not have a guest network on
Yeah, lemme see what I can do about that. For some reason, print screen doesn't work on windows. For some reason Chrome in Linux isn't letting me log into the router.
maybe your system is pwnd which is why this attacker has instant access to changes.
Have you run a virus scan from a bootable media like CD or USB?
Use snipping tool?
[admin login] from source 192.168.0.100, Tuesday, March 28,2017 13:48:34
[admin login] from source 192.168.0.100, Tuesday, March 28,2017 13:25:46
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 13:00:10
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 13:00:00
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 12:59:50
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 12:59:27
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 12:30:13
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 12:30:03
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 12:29:54
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 12:29:26
[DoS attack: RST Scan] from source: 96.38.234.171:51918, Tuesday, March 28,2017 11:49:33
[DoS attack: RST Scan] from source: 71.227.159.6:7680, Tuesday, March 28,2017 11:48:48
[DHCP IP: (192.168.0.6)] to MAC address 08:05:81:C8:39:29, Tuesday, March 28,2017 11:40:01
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Tuesday, March 28,2017 11:39:55
[DHCP IP: (192.168.0.2)] to MAC address F4:F5:24:73:C6:58, Tuesday, March 28,2017 11:39:55
[Time synchronized with NTP server time-a.netgear.com] Tuesday, March 28,2017 11:38:59
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Tuesday, March 28,2017 11:35:22
[admin login] from source 192.168.0.100, Tuesday, March 28,2017 11:30:28
[admin login] from source 192.168.0.100, Tuesday, March 28,2017 11:18:05
[DHCP IP: (192.168.0.6)] to MAC address 08:05:81:C8:39:29, Tuesday, March 28,2017 11:13:56
[admin login] from source 192.168.0.100, Tuesday, March 28,2017 10:58:21
[DoS attack: RST Scan] from source: 157.240.2.35:443, Tuesday, March 28,2017 10:49:54
[DoS attack: RST Scan] from source: 31.13.74.7:443, Tuesday, March 28,2017 10:49:27
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 10:30:34
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 10:30:13
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 10:29:53
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 10:29:27
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 10:00:13
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 10:00:03
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 09:59:53
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 09:59:25
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 09:30:10
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 09:30:00
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 09:29:50
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 09:29:25
[DHCP IP: (192.168.0.2)] to MAC address F4:F5:24:73:C6:58, Tuesday, March 28,2017 08:32:29
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 08:30:13
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 08:30:03
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 08:29:53
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 08:29:26
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Tuesday, March 28,2017 08:06:11
[DoS attack: RST Scan] from source: 71.227.159.6:7680, Tuesday, March 28,2017 07:53:07
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 07:30:11
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 07:30:01
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 07:29:52
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 07:29:26
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 07:00:32
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 07:00:11
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 06:59:51
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 06:59:28
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 06:00:13
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 06:00:03
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 05:59:53
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 05:59:25
[DoS attack: RST Scan] from source: 23.54.43.135:80, Tuesday, March 28,2017 05:15:35
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 05:00:12
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 05:00:02
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 04:59:52
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 04:59:26
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 04:00:32
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 04:00:11
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 03:59:50
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 03:59:25
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 03:00:10
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 03:00:00
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 02:59:50
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 02:59:24
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 02:00:22
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 02:00:12
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 01:59:52
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 01:59:25
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 01:30:32
[DoS attack: RST Scan] from source: 103.224.182.250:80, Tuesday, March 28,2017 01:30:21
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 01:30:12
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 01:29:51
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 01:29:26
[DoS attack: RST Scan] from source: 108.61.236.112:80, Tuesday, March 28,2017 01:17:01
[Time synchronized with NTP server time-a.netgear.com] Tuesday, March 28,2017 01:16:12
[DoS attack: RST Scan] from source: 104.156.245.157:80, Tuesday, March 28,2017 01:05:34
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 00:30:13
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 00:30:03
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 00:29:53
[admin login failure] from source 192.168.0.194, Tuesday, March 28,2017 00:29:25
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Monday, March 27,2017 23:35:21
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 23:30:12
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 23:30:02
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 23:29:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 23:29:27
[DHCP IP: (192.168.0.6)] to MAC address 08:05:81:C8:39:29, Monday, March 27,2017 23:13:55
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 23:00:36
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 23:00:15
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 22:59:55
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 22:59:27
[DoS attack: RST Scan] from source: 14.182.33.124:52502, Monday, March 27,2017 22:44:18
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 22:30:34
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 22:30:13
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 22:29:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 22:29:26
[DoS attack: RST Scan] from source: 31.13.74.7:443, Monday, March 27,2017 22:24:07
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 21:30:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 21:30:04
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 21:29:54
[DoS attack: RST Scan] from source: 157.240.2.20:443, Monday, March 27,2017 21:11:37
[DoS attack: RST Scan] from source: 157.240.2.7:443, Monday, March 27,2017 21:11:03
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 21:00:12
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 21:00:02
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 20:59:52
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 20:59:28
[DHCP IP: (192.168.0.2)] to MAC address F4:F5:24:73:C6:58, Monday, March 27,2017 20:32:28
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 20:30:35
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 20:30:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 20:29:53
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Monday, March 27,2017 20:29:46
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 20:29:25
[DoS attack: RST Scan] from source: 157.240.2.20:443, Monday, March 27,2017 20:28:03
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 20:06:01
[DoS attack: RST Scan] from source: 198.232.124.36:443, Monday, March 27,2017 19:57:52
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 19:30:34
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 19:30:13
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 19:29:52
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 19:29:27
[DoS attack: RST Scan] from source: 31.13.74.14:443, Monday, March 27,2017 19:14:08
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 18:30:12
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 18:30:02
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 18:29:52
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 18:29:26
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 17:30:13
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 17:30:03
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 17:29:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 17:29:27
[DoS attack: RST Scan] from source: 205.185.208.154:443, Monday, March 27,2017 16:39:58
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 16:39:04
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 16:38:00
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 16:36:53
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 16:30:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 16:30:34
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 16:30:13
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 16:29:52
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 16:29:27
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 16:00:12
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 16:00:02
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 15:59:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 15:59:26
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 15:42:12
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 15:34:03
[DHCP IP: (192.168.0.9)] to MAC address 24:DA:9B:63:0E:8E, Monday, March 27,2017 15:30:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 15:00:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 15:00:04
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 14:59:54
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 14:59:26
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 14:00:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 14:00:04
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 13:59:55
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 13:59:25
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 13:30:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 13:30:04
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 13:29:54
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 13:29:26
[DoS attack: RST Scan] from source: 31.13.74.7:443, Monday, March 27,2017 13:18:43
[DoS attack: RST Scan] from source: 157.240.2.20:443, Monday, March 27,2017 13:17:28
[DoS attack: RST Scan] from source: 45.76.37.210:80, Monday, March 27,2017 12:36:03
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 12:30:33
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 12:30:12
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 12:29:51
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 12:29:26
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 12:00:33
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 12:00:12
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 11:59:51
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 11:59:25
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Monday, March 27,2017 11:33:27
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 11:30:00
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 11:29:50
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 11:29:41
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 11:29:17
[DoS attack: RST Scan] from source: 157.240.2.20:443, Monday, March 27,2017 11:25:52
[DHCP IP: (192.168.0.6)] to MAC address 08:05:81:C8:39:29, Monday, March 27,2017 11:13:56
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 10:30:15
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 10:30:05
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 10:29:55
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 10:29:26
[DoS attack: RST Scan] from source: 61.92.18.206:47143, Monday, March 27,2017 10:17:10
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 10:00:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 10:00:03
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 09:59:54
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 09:59:26
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 09:00:17
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 09:00:06
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 08:59:57
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 08:59:27
[DHCP IP: (192.168.0.2)] to MAC address F4:F5:24:73:C6:58, Monday, March 27,2017 08:32:29
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 08:00:11
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 08:00:01
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 07:59:51
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 07:59:26
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 07:00:34
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 07:00:13
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 06:59:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 06:59:26
[DHCP IP: (192.168.0.2)] to MAC address F4:F5:24:73:C6:58, Monday, March 27,2017 06:18:09
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 06:00:22
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 06:00:12
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 05:59:52
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 05:59:26
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 05:00:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 05:00:04
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 04:59:53
[DHCP IP: (192.168.0.4)] to MAC address 68:C4:4D:6C:B9:25, Monday, March 27,2017 04:59:43
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 04:59:27
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 04:30:11
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 04:30:01
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 04:29:52
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 04:29:24
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 03:30:15
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 03:30:05
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 03:29:55
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 03:29:29
[DoS attack: RST Scan] from source: 209.254.160.42:35854, Monday, March 27,2017 03:11:45
[DHCP IP: (192.168.0.6)] to MAC address 08:05:81:C8:39:29, Monday, March 27,2017 03:01:31
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 03:00:13
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 03:00:03
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 02:59:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 02:59:27
[DoS attack: RST Scan] from source: 94.25.177.26:80, Monday, March 27,2017 02:29:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 02:00:35
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 02:00:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 01:59:53
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 01:59:27
[Time synchronized with NTP server time-a.netgear.com] Monday, March 27,2017 01:16:08
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 01:00:14
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 01:00:04
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 00:59:54
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 00:59:27
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 00:00:13
[admin login failure] from source 192.168.0.194, Monday, March 27,2017 00:00:03
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 23:59:54
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 23:59:27
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Sunday, March 26,2017 23:33:26
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 23:00:35
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 23:00:14
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 22:59:53
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 22:59:27
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 22:30:33
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 22:30:12
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 22:29:52
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 22:29:27
[DoS attack: RST Scan] from source: 185.58.205.117:80, Sunday, March 26,2017 21:52:19
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 21:30:15
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 21:30:05
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 21:29:55
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 21:29:26
[DoS attack: RST Scan] from source: 31.13.74.40:443, Sunday, March 26,2017 21:26:42
[DoS attack: RST Scan] from source: 157.240.2.41:443, Sunday, March 26,2017 20:46:22
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 20:30:12
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 20:30:02
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 20:29:52
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 20:29:29
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 20:00:11
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 20:00:01
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 19:59:51
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 19:59:25
[DHCP IP: (192.168.0.4)] to MAC address 68:C4:4D:6C:B9:25, Sunday, March 26,2017 19:26:08
[DoS attack: RST Scan] from source: 31.13.74.7:443, Sunday, March 26,2017 19:16:51
[DoS attack: RST Scan] from source: 157.240.2.21:443, Sunday, March 26,2017 19:16:28
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 19:12:32
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Sunday, March 26,2017 19:04:31
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Sunday, March 26,2017 19:01:24
[DoS attack: RST Scan] from source: 23.209.57.129:443, Sunday, March 26,2017 19:00:38
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 19:00:10
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 19:00:00
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 18:59:50
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 18:59:27
[DoS attack: RST Scan] from source: 157.240.2.20:443, Sunday, March 26,2017 18:38:42
[DHCP IP: (192.168.0.4)] to MAC address 68:C4:4D:6C:B9:25, Sunday, March 26,2017 18:31:44
[DHCP IP: (192.168.0.2)] to MAC address F4:F5:24:73:C6:58, Sunday, March 26,2017 18:18:08
[DHCP IP: (192.168.0.185)] to MAC address 0C:FE:45:9D:8E:83, Sunday, March 26,2017 18:10:46
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 18:00:29
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 18:00:07
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 17:59:46
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 17:59:26
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 17:30:34
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 17:30:13
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 17:29:52
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 17:29:25
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 16:30:13
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 16:30:03
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 16:29:53
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 16:29:26
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 16:00:32
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 16:00:11
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 15:59:51
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 15:59:26
[DHCP IP: (192.168.0.6)] to MAC address 08:05:81:C8:39:29, Sunday, March 26,2017 15:01:32
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 15:00:10
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 15:00:00
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 14:59:51
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 14:59:25
[DHCP IP: (192.168.0.4)] to MAC address 68:C4:4D:6C:B9:25, Sunday, March 26,2017 14:46:41
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 14:30:32
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 14:30:11
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 14:29:50
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 14:29:26
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 13:52:28
[DoS attack: RST Scan] from source: 157.240.2.20:443, Sunday, March 26,2017 13:46:13
[DoS attack: RST Scan] from source: 31.13.74.1:443, Sunday, March 26,2017 13:45:53
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 13:30:12
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 13:30:02
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 13:29:52
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 13:29:25
[DoS attack: RST Scan] from source: 157.240.2.20:443, Sunday, March 26,2017 12:55:53
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 12:40:13
[DoS attack: RST Scan] from source: 216.58.192.163:443, Sunday, March 26,2017 12:37:35
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 12:30:24
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 12:30:03
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 12:29:42
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 12:29:18
[DoS attack: RST Scan] from source: 128.107.241.191:52024, Sunday, March 26,2017 12:04:06
[DHCP IP: (192.168.0.2)] to MAC address F4:F5:24:73:C6:58, Sunday, March 26,2017 11:54:18
[DoS attack: RST Scan] from source: 52.43.115.227:443, Sunday, March 26,2017 11:37:28
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 11:30:13
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 11:30:02
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 11:29:53
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 11:29:26
[DHCP IP: (192.168.0.4)] to MAC address 68:C4:4D:6C:B9:25, Sunday, March 26,2017 11:27:04
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 11:22:41
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 11:11:09
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 11:09:49
[DoS attack: RST Scan] from source: 157.240.2.35:443, Sunday, March 26,2017 11:08:03
[DoS attack: RST Scan] from source: 31.13.74.7:443, Sunday, March 26,2017 11:06:36
[DoS attack: RST Scan] from source: 157.240.2.35:443, Sunday, March 26,2017 11:04:53
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 11:02:52
[DoS attack: RST Scan] from source: 157.240.2.25:443, Sunday, March 26,2017 11:01:01
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 11:00:35
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 11:00:14
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 10:59:53
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 10:59:27
[LAN access from remote] from 80.82.65.66:41131 to 192.168.0.100:7783, Sunday, March 26,2017 10:55:47
[LAN access from remote] from 80.82.65.66:41131 to 192.168.0.100:7783, Sunday, March 26,2017 10:55:42
[DoS attack: RST Scan] from source: 157.240.2.20:443, Sunday, March 26,2017 10:51:28
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 10:00:12
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 10:00:02
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 09:59:52
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 09:59:27
[DHCP IP: (192.168.0.8)] to MAC address F8:95:C7:E1:FC:92, Sunday, March 26,2017 09:31:09
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 09:00:11
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 09:00:01
[DoS attack: RST Scan] from source: 23.196.51.71:80, Sunday, March 26,2017 08:59:59
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 08:59:51
[admin login failure] from source 192.168.0.194, Sunday, March 26,2017 08:59:26
Can't get info from modem that was showing all the data I was looking at earlier. ISP let me get into modem to watch traffic, but now I can't get in.
Also, I just recently wiped all my systems due to a bad batch of harddrives all failing in the same day. Had to resort to old hard drives till my wife can buy new ones. I THINK they are all clean.
The problem with your setup is it might be vulnerable to WPS attacks even if the routers firmware has it turned "off" because in some cheaper options its just disabling the WPS button but will still accept keys. This sounds exactly like a pixiewps attack to me.
Also what @NetBandit said could be a very real possibility.
I would check to see if maybe DD-WRT is an option for that router.
EDIT: I checked DD-WRT is a no go.
Why so many admin login failures?
I have no idea. and that's one of IP's i've blocked too. It's none of my devices.
Is this a cable company owned router?
Is it up to date on router firmware?
If it's yours, DD-WRT isn't a bad option.
If it is the cable companies, put it into modem (aka bridge) mode and get your own router.
No go on ddwrt and doesnt look like its a cable/router combo.
What is going on with lan access from remote and that 80 ip address?
This is my own router. I just bought it like two weeks ago hoping to solve this problem. When I started this post, is when the cable company called me. Since I'm out of ideas, I figured I'd come here.
Don't know bout the 80 ip address, and the .100 ip is me. So other than the ip's ending in a single digit like .2 and .6 which are my cellphones in my house from wife and kids, none of the rest are me.
Edit: Servers are on a different router not associated with anything internet. And not connected to this router at all.
Also, on my old router, the logs looked exactly like this. Tons of traffic, and ISP still yelling at me.
