I posted this on another site that shall not be named, and I received no responses after a week. It's not the first time this has happened. I want to make sure I haven't looked anything before I replace the router.
I've got WiFi a connection/speed problem with my Netgear Nighthawk R7000.
A few weeks ago, I noticed a drop in performance on the 5 GHz band. At first it was only noticeable when gaming, which was similar to when gaming on 2.4 Ghz, where I seemed to get lag spikes at regular intervals. However, I was getting major lag spikes on 5 GHz now, but then I noticed them happening more frequently, and finally, I noticed my browsing was affected. Upon attempting to load a multi-megabyte image, it would load line by line, a haunting similarity to the days of dial-up. I used the nearest of my ISP's servers on Speedtest, and my speed was down to 1 Mb, if that. The 2.4 Ghz band tested normal at 60 Mb or faster. The 5 GHz network is on a high channel with no interference, while the 2.4 GHz network has 3-4 other networks competing with it. My signal strength is at or near full.
Here's your TL;DR
Setup
Router - Netgear Nighthawk R7000 firmware v1.0.7.2 2.4
- 2.4 GHz - ch 6
- 5 GHz - ch 153
- WiFi Analyzer was used to analyze signal interference to select these channels
- AC adapter is the one the router came with
WIFI Adapter - Asus USB AC56
- Originally set to AC only mode when problem experienced
- Modem - Arris TM822G
Troubleshooting
- Reset modem and router - no effect
- Check modem telemetry - all downstream channels ≥36 dB
- Upgraded router firmware
Called ISP - they said modem was fine
- Connected straight through modem - speeds are fast, modem starts dropping like crazy after ~90 mins
- Called ISP again - connect straight through modem again, no drop in performance this time, tested for 4 hrs
- Connect through LAN - speeds are fast
- Reinstalled WiFi adapter - no effect
Try every router version of firmware from version 1.0.7.2-1.0.4.8 - no effect
- Try every router version of firmware from version 1.0.7.2-1.0.4.8, this time resetting between firmware changes - one time 5 GHz came back to life, but after renaming networks, was back to slow, unable to reproduce consistently
- Tried switching to all the 100-range channels on the 5 GHz spectrum - no effect
- Tried switching between various WiFi standards on the adapter - no effect
- I'm not willing to install DD-WRT or Tomato without a fallback option, as I can still use the 2.4 GHz band. I'd have no internet access if custom firmware doesn't work and can't restore without a console adapter, which I don't have, if standard restoration methods don't work.
Findings
- Modem not the problem
- 2.4 GHz band is normal
- Link rate on both bands is normal
- Upload speeds on both bands is normal
- Speeds are affected on my phone as well, so it's not the WiFi adapter
- Antennae are tight and in their proper positions
- All signs point to router
Details
The first thing I did was check the modem's telemetry. All the downstream channels had an SNR of 36 dB or greater! For those of you reading that don't know, noise can kill all your networking equipment if left unchecked. Of course I suspect the modem, but then I remembered the last time I had performance problems on 5 GHz, a firmware downgrade did the trick. The thing that was alarming here was, I made no changes that would've caused the slowdown, unlike last time when I upgraded the firmware. I upgraded the firmware to v1.0.7.2. No effect. In fact, sometimes I couldn't even connect to 5 GHz. I used to get kicked from 5 GHz once in a while. Usually running the Windows Network Troubleshooter would restore the connection, rarely would I have to go power cycle the router to restore the connection. This was no longer working. If I was lucky, I could connect after running the Troubleshooter several times. Although, I noticed my phone stayed connected all the time with no perceptible drop in performance before this event.
I called my ISP, suspecting the modem, and maybe they could send a signal to straighten things out. Of course, they tell me to connect straight through the modem, but the offshored agent is useless beyond that, offering to schedule a service call. (I have my own router and modem, so this would cost me). I noticed no performance degradation straight through the modem. I've used all the same cables to rule out a bad cable. I watched the SNR numbers slowly rise on each channel. Then, about 90 minutes in, the connection came crashing down hard. I couldn't even stay connected to the game server: drops every few minutes, telemetry was over 36 dB on every channel. I noticed it was really warm in the room that day, and suspected a heat problem. After I was done "stress testing," I plugged in the dust blower and blew it out.
The problem still persisted. I couldn't do anything during the week, so I just endured it for the time being. I called the ISP again this weekend, and of course, they make me connect directly through the modem...again. The competent, agent (whose workplace seems to be located in my country) says everything looks fine, and I could schedule a service call, "won't cost you if you sign up for our cheap service plan for at least 60 days," but I decide to "stress test" the modem again, by gaming. After four hours, the telemetry is still within tolerable levels. I conclude the modem isn't the problem. I used all the same cables to rule out a bad cable, of course.
I have an AC wireless adapter: the Asus USB AC56. Still works fine on 2.4 GHz, but that's not the point of having it. Oh, and my upload speeds have not been affected. They remain at 10 Mb or faster. I reinstalled it, but 5 GHz was still slow, if it could connect at all.
The next thing I did was try every version of firmware from the most recent to a significantly older version: 1.0.7.2-1.0.4.8, no effect. Speedtests on my phone over the network were of similar performance, so the problem is the WiFi. I then wired up to the router, performance and telemetry was within tolerable limits. What I didn't do and didn't realize was that I should factory restore the router every time the firmware is updated. >_< So I then did this with every version I had. I can't remember what version it was, but at some point 5 GHz sprang to life and I had over 200 Mb on Speedtest. However, when I renamed the networks from the default, and tested again, it crapped out. I was only able to replicate this one additional time, and it seemed to have something to do with factory resetting, holding the nuke button, and testing as soon as the router would allow internet access after initial setup, not sure what firmware version it was, and I don't have the patience to go through it all over again. Again, changing an inconsequential setting borked 5 GHz.
So I'm stuck. I spent all day yesterday troubleshooting, and at this point, I'm cursing Netgear and considering a new router. I've had it 13 months, so it's just out-of-warranty. >_< Never getting Netgear again, should've went with the Asus model. If anyone has any suggestions for fixing my router, please let me know. I have considered flashing DD-WRT or Tomato, but I'm not comfortable doing this without a backup, as 2.4 GHz still works, and I don't have a console connector to restore firmware if standard restoration methods don't work. I've been thinking about getting a wired router and hooking up an AP to it, so I can just replace the AP when it fails instead, but this might actually cost me more at first. I'll probably just get the ASUS RT-AC68U.
I'm sorry for the long post, but I was as thorough as I possibly could have been with troubleshooting before asking for help.
Edit
It occurred to me that the modem could've killed the 5 GHz antenna, as the SNR ranges between 34-35 dB. Modem tech support told me when I first bought it that over 33 dB was bad. I don't know how this makes any sense though, since higher SNR means less noise on the line, not more.
