NetApp DS4243 and ZFS issues
I’ve set up a similar setup to @wendell with a used NetApp DS4243, QSFP+ to mini-SAS cable, LSI 9201-16e, and Dell PowerEdge 610 with 64GB RAM. It has 14x 8TB drives in it and so far it has been a breeze… except one thing which I’m curious to see if anyone else has experienced. It seems the SAS interposers that are required to use SATA disks in the shelf are limiting the SMART values being passed to FreeNAS. For example, there’s only general “health status”, temperature, hours on, and start-stop. It is missing common SMART values that would help in detecting early drive failure like pending sectors, etc. Although I think the magic of ZFS will mostly cover up this flaw by ratting out drives that are writing corrupt data it is still a disappointment to see. Anyone else experience this or have a workaround? I posted in the FreeNAS forum with more details if you’re interested: https://forums.freenas.org/index.php?threads/netapp-ds4243-and-lsi-9201-16e-missing-smart-values.68739/
Thanks for your input. I see we are thinking the same thing. Currently the 14 drives are in two RAIDZ vdevs of 7 but this disk shelf will be just one of three in a string of primary, backup, and offsite backup FreeNAS servers with similar setups.
Are you using the SAS2 Falcon drivers for your controller, by any chance? (Just curious)
No, just the default updated LSI firmware.
Not sure if this is related but LUNO seems to have hijacked my IRST which also provides my S.M.A.R.T. data. I have no idea what the consequences of this might be but I noticed that booting back to the IRST O/S from LUNO always results in a rebuild on my mechanical drives. Perhaps I’m expecting too much from one main board. Other than that everything works fine. My LSI card only has 8 ports so I’m not using anything that elaborate. In fact, only 4 of the ports are used for RAID 10. So far this thread is the closest thing I’ve found to anything here addressing my issue. Thanks for posting. It has given me some ideas. :slight_smile:
