I have a Netapp 4243. I know the onboard IOM 3. I believe the IOM 3 has a limit of 3tb drives. Is there an upgrade I can use to get it to read 8tb drives?
You need to upgrade to an IOM6 for each controller in use.
Thank you
You’re welcome.
They’re had pretty cheap on EBay.
For example, here’s one for $30. Though sometimes you can find deals if you get a couple at a time. (This is the same one I got my DS4243)
