.net framework problems
whenever i try to use a program that requires 3.5 it says this (for example nexus mod manager, and the first 2 batman games) its really becoming a pain in the ass please help idon't know what to do here.
The message says,
the following feature could not be installed: .net framework 3.5 (includes .net 2.0 and 3.0)
the configuration registry database is corrupt. error code 0x8000703f1
i had something similar with curse client install, problem with .net is that it tends to overwrite itself constantly, steam does it when installing new games that require it and so on, at some point, shit gets mixed up with the new and old versions that it simply wont work, and you cant simply re-install it, cauz when you uninstall it, some parts of it remain and still keep fucking with you, but i'm blabbering so here is a few things you can do.
http://sompka.blogspot.com/2012/11/curse-client-v5-errors-problems.html
none of them really worked for me. every time i try to just install 2.0 or 3.5 it says i need 3.5 in order to install it which is weird.
is there a way that i can manually insstall it by placing the files in my computer, editing the registry etc etc
