I completed my first ever water loop about a month ago after a few adventures( multiple DOA cpu's and SSD's)
and the temps coming out of the radiator are about the same as going into my graphics cards. is there some issue im missing? i dont seem to be getting very good temps. Idle around 90F and load about 106F. this is Running borderlands 2 at max settings. my ambient temp is about 75F.
Well, what is your system specs? Whats linked into the loop? What size are your radiators?
Your max temp seems about right (depending on the amount of rads)
Also bear in mind that a watercooling loop doesn't show much temperature difference overall as the liquid is moving pretty quickly around the loop.
- zanginator
AMD FX 8130 Water cooled.32GB G.Skill Sniper
2x 128 GB Kingston SSD.
Dual GTX 680 SLI. Water Cooled.
Alphacool VPP655 Variable Speed Pump
The OCZ Fatal1ty 1000W PSU (fully sleeved)
Still rockin lego's
