Hi folks
My setup B350M Pro VDH ryzen 1700X/64GB RAM/1TB SSD/1080ti
Mostly used for virtual machines 24/7 and some editing now and then, gaming not that much nowadays.
I have to run lots of win vmware instances with a specific app. 2GB RAM is enough for each one.
IM getting to the point of having 90% RAM usage,lots of swap% and CPU also not stable anymore. Im able to run around 30 instances before getting into trouble.
My options right now are :
Threadripper 2950 X / 2970WX
AMD EPYC 7351 / 7401P
I will also add more 64GB of RAM and more storage. NVME´s probably not worth it?
Each VM is pretty light, not much clock demanding.
Would I be better with the 7401 24core Epyc in this case since it has more cores and the capability of increasing beyond 128GB Ram in the future if needed to?
Thanks
