Budget: $2,000
Perihperals: i could use a mouse and keyboard while im at it. maybe a headset too. all this is optional if within budget.
Use: Gaming, RAW photos, light home video rendering, streaming 1080p videos.
Overclock: either way
Watercooling: yes, im in texas and it gets hot! especially if overclocking.
oS: Windows 7.
BTC: if i have the specs above, with no stress issues, sure!
game use
settings: ultra
resolution: i have a single asus vs228 monitor
games: first person shooters
specificly, battlefield 4!
for home videos i use adobe or sony vegas but for photos i use lightroom and photoshop.
considering your current specifications listed above i went on the american amazon (bit weird for me as i am british) and put to gether a very quick build that has been running like a BEAST for me. the parts that i list here will come to roughly $1600 with the $400 you can easily get a decent closed loop corsair waterblock for the CPU. BTW this is an intel/Nvidia build as you said you had video rendering i went for the CUDA.
http://www.amazon.com/Intel-Core-i5-3570K-Quad-Core-Processor/dp/B007SZ0E1K/ref=sr_1_2?ie=UTF8&qid=1380673958&sr=8-2&keywords=i5 - still a very viable and fast proccesor, i7 probably not needed in your case
http://www.amazon.com/ASUS-P8Z77-V-LX-Intel-Motherboard/dp/B007MKGF82/ref=sr_1_1?ie=UTF8&qid=1380674002&sr=8-1&keywords=asus+mother - FILLED with very good features, easy to use bios and SO easy to fit into nearly every case out there
http://www.amazon.com/EVGA-GeForce-GTX780-SuperClocked-03G-P4-2784-KR/dp/B00CUIVSNS/ref=sr_1_1?ie=UTF8&qid=1380674090&sr=8-1&keywords=780 - its a GTX 780, do i need to say anymore? (could also swap this EVGA version out for the ASUS direct CU II if you like)
http://www.amazon.com/Thermal-Direct-GPU-Contact-Graphics-GTX780-DC2OC-3GD5/dp/B00DWV3NM6/ref=sr_1_5?ie=UTF8&qid=1380674090&sr=8-5&keywords=780
http://www.amazon.com/Samsung-MZ-7TD250BW-Series-Solid-2-5-Inch/dp/B009NHAEXE/ref=sr_1_2?ie=UTF8&qid=1380674187&sr=8-2&keywords=256gb+ssd - brilliant SSD 256GB for main programs, OS and other such stuff,
http://www.amazon.com/Corsair-Gaming-Series-700-Watt-GS700/dp/B00ALSNDS2/ref=sr_1_1?ie=UTF8&qid=1380674537&sr=8-1&keywords=700w+corsair - good 700W PSU, could go for the 800W if you like, but im very sure this baby will do you just fine
http://www.amazon.com/Kingston-1866MHz-PC3-15000-KHX18C9T3K2-8X/dp/B00A771ZSW/ref=sr_1_21?ie=UTF8&qid=1380674047&sr=8-21&keywords=8gb+1866+ram - 8GB of 1866MHz RAM, quick cheap just GOOD ram (recomended by logan)
http://www.amazon.com/Corsair-Series-Extreme-Performance-Liquid/dp/B009ZN2NH6/ref=sr_1_1?ie=UTF8&qid=1380674683&sr=8-1&keywords=CPU+corsair - one of my friends recently installed this, his temps are silly low, doesnt budge from idle temps sometimes.
Those are all the parts i will list, that gives you roughly $300 on a case and any other accessories such as mouse/keyboard/headset, personally im using the microsoft sidewinder x4, not mechanicalbut nice feel for £30 ($60) at a guess, mouse is a mionix noas cant go wrong so comfy brilliant customisation options within the software, headset is a steelsieries siberia v2, allround great sound with a very reasonable microphone, had people comment on how good it is for how cheap it is.
hope i helped in some way :) if you have any questions about the build or just want to bouce some ideas off me just ask :D good luck
thanks! ill check it out.
forgot to put that but yes, america. lol. i also remembered but failed to put it in at the end... i would preffer newegg since i have $2000 credit. i will have to get the cash to pay on amazon which will take me longer although i have the cash, id rather pay it off in a year with newegg having 0 interest if paid before the year. that leaves me with cash just in case something comes up.
well im sure you could transpose those items into newegg :) they will more than likely have the same stock. also its 2am here so excuse some grammatical errors and try to see through the english -> american translation :D
Very nice budget :3. Let's see...
http://pcpartpicker.com/p/1JPv6
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor. You can afford it, and will help with video rendering.
CPU COOLER: Corsair H100i 77.0 CFM Liquid CPU Cooler. Nice AIO liquid cooler, as requested.
MOBO: MSI Z87-G45 Gaming ATX LGA1150 Motherboard. Good featureset, looks great.
RAM: Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory. This'll last awhile. 16GB is probably more than you need, but the budget was there.
SSD: Kingston HyperX 3K 120GB 2.5" Solid State Disk. Put WIN7 and you're most commonly used programs on here for super fast speeds.
HDD: Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard Drive. 2TB for storage.
GPU: Gigabyte GeForce GTX 780 3GB Video Card. One hell of a card, and has a great cooler on it.
CASE: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case. Has great airflow, since you'll need it in TX. Also, has a window, and the parts I picked should look epic.
PSU: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply. This is all you need, unless you go SLI. It's a rebranded Seasonic, and runs great.
OD: Lite-On iHAS124-04 DVD/CD Writer. Simple drive if you need it.
OS: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit). As requested.
PERIPHERALS
KB: Corsair Vengeance K70 Wired Gaming Keyboard. Best keyboard imho, looks epic and has everything i'd want.
MOUSE: Razer DeathAdder 2013 Wired Optical Mouse. Everyone loves the deathadder.
HEADSET: SteelSeries Siberia V2 Headset. Comfortable headset for the money, has a great mic.
