So this issue is a continuation of this one http://teksyndicate.com/forum/hdds-ssds/cant-format-c-drive-after-partition/133641 The problem im having is nothing im doing is working. My computer is completely bricked at this point. The ubuntu disk i made doesnt help either as it wont install on my partitions. (tired of booting from slow cd). Im so screwed right now.
any help would be GREATLY apretiated. here is a picture of the screen im currently facing on my windows repair disc
Get this and use this tool that is included.
It is by far the easiest way to fix a MBR I have ever used.
Oh and if you dont have access to another computer to get the ubnuntu secure remix you can just install the boot repair tool by doing
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
then
sudo apt-get install -y boot-repair && boot-repair &
You can also try D7. Its free and portable.
