Need To Know what to go with
dont know if to go with the HIS IceQ Boost Clock H75qc4g2m Radeon HD 7950 3gb or with the
HIS IceQ H787Q2G2M Radeon HD 7870 GHz Edition 2gb. but if know of beter card for about the
same price just let me know  also my processor is the AMD A10- 5800k Trinity 3.8
IF they're the same price, 7950 easy. But make sure your power supply can accommodate it.
right now 7950 is like 50 bucks more also dont know if my power supply can accommodate ? here are my sepcs. want to know if it can do the 7870. if my power supply is not good for these gpu's what would be a good power supply ?
ASRock FM2A75M-DGS FM2 AMD A75 (Hudson D3) SATA 6G
AMD A10-5800K Trinity 3.8GHz (4.2GHz Turbo) Socket
G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDR
Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB C
Cooler Master HAF 912 - Mid Tower Computer Case with High Airflow Design
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
CORSAIR Builder Series CX500 500W ATX12V v2.3 80 P
yes it will be able to handle it
Yeah you will be fine with that PSU I have a MSI 7870 Hawk and I'm using the CX500.
