with this YMDK Wings Kit do i need to do any Soldering im i reading it this right
or this one
if i am can i still open it up to add some vibration dampening pads
an if i go with the keycaps off this board
an use them on the ymdk wings would i still get the space gap between the keys this is important to me
my planned build is the ymdk with plus the keycaps off the 2088-Black
with a full set of KAILH BOX DARK YELLOW SWITCHES an GLORIOUS O-RING SWITCH DAMPENERS 40a soft
either thin or thick not sure which would be best
an to top off build was going to give a custom paint job by adding a spray painted white pattern not sue what id go with yet.
any advice on initial ask an any on planed paint scheme will be welcomed
note i like a heavier trigger
an my reason for wanting the low profile caps off that
board
is iv got on my current pc build a drop swift with
kailh heavy box ancient greys an on the num pad the box dark yellows
with these caps - Retro Steampunk Keycaps Set
i like the gap spacing an the round shape but for ymdk id like square ones
but cant find a good stand alone set other then the one on the mentioned
2088-Black an i was just trying to confirm the 2088-Black caps on the
ymdk wings board would still have the gap spacing ?
