Need to Build an Overpowered PC for 4K rendering and movie editing/production
Hello,
I am in need for a new editing rig capable of rendering videos in 4K quickly. I am an amateur film maker/editor, and need a whole rig setup. I am looking for a fully upgradable rig with the best. I'm looking for a Quad-SLI rig with dual processors (intel) to render in 4K very quickly. I use DaVinci Resolve for my editing/color correcting, and Adobe After Effects for my action/lens flare type scenes. I have no limit on the price, but would like a bunch of storage. I would also like someone to recommend a very precise headphone for audio editing.
Thanks,
jakedabomb
RIVBe
4960X
8X8GB 3133MHz DDR3
Quad 780Ti K|NGP|N
Six 512GB Samsung 840 Pros
OR
Power8
4GHz Stock
1536-Thread
Multi Chip Module
64-Bit PowerPCv2.07
32x64GB XDR2 6GHz
The Beast Socket 4096
Eight 780Ti K|NGP|N PLX chip and hacked PowerPC Linux drivers
Phase Cooling
Can you be more specific on this? I need to know the brands of these modules.
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131817
2 CPU's (you may choose different Xeons to fit your budget)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117266
Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231713
4 GPU's
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130942
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182251
2 4TB HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178338
SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147250
Use whatever case you want but I just put this for an example
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
Again you can look around at different CPUs if thats out of your budget or if you want more just get a faster pair.
for headphones I would go with the beyerdynamic DT880s. Same one logan has. Those are very Neutral headphones.
