Budget. How much are you willing to spend? - $350ish Where do you live? - Tulsa/USD Is there a retailer you prefer? - No Do you need or already have peripherals? Yes. Do you overclock or want to get into overclocking? - no Do you plan on going for custom water-cooling now, or in the future? No Operating System. Ubuntu
a8....750 watt PSU? 7850k will work fine on a 220 watt OEM PSU from the bottom of the barrel emachines rig. Saw one guy get a good antec PSU for under 20 bucks on ebay. You can add a cpu cooler anytime and AMD coolers have greatly improved If you're near a microcenter go with a combo. Also check out open box stuff at nearby retailers. scored a nice antec case with psu for 45 bucks cause it had a scratch. 16 gig on a linux build? Used X4 and a 270 370 950 etc will work great also. When my x3 went from 8 to 4 gig I switched to mint and it did fine. OK microcenter aint in your state. You can print out the combo you like and see if Best Buy will do their price match garentee, never tried this but other guys have. Awesome price on the MB, avoid MSI Hope this helps
Yeah, the price is starting to get a bit higher than I'd like, but then again I'm in no hurry, I can wait for prices to drop and/or get stuff piece meal....
