{{PcPartPicker Link Is At The Bottom, Please Read Whole Post First}}
I want to play PlanetSide 2 at medium preset (or better) 1920x1080 with a MINIMUM frame-rate of 30fps (as in it will never go below 30 unless there is a serious anomaly)
Colors should be Red, Blue, Green, or Yellow On Black, with any shade of White, Grey or Silver, and/or mild gold accenting allowable
I'm not a brand loyalist, just nothing obscure, unknown, or pure crapola. Reliability\Performance\Price, you can only pick 2 so i pick the first 2.
And the whole Nvidia, Amd, or Intel war, i really don't care, best bang for buck/most compatibility with games
Moderately Possible 2 way CrossFire/SLI in the future
Highly probable mild to moderate overclocking
Mildly possible custom water-cooling in the future
Motherboard expansion slots need to be specific
- PCI-E X16 GPU Slot
- Don't Care
- PCI-E X1 Sound Card Slot
OR
- Don't Care
Or any other configuration where it will fit 2 dual slot GFX cards with an un-hindered PCI-E X1 slot for a sound card
NOTE:: Only Put The Standard Components Into The Build (CPU, Mobo, Ram, GPU, PSU, and Storage) I have a separate parts list with everything else and the Disc Drive, OS and Case are in the link
http://pcpartpicker.com/user/Mr.DHbigmac/saved/RCDkcf
